Ryeandwater
Thread starter- Joined
- Jul 2, 2012
- 9
Motor running great, while winterizing, I had it running on the muffs, cowl off and I noticed water leaking around the square black thing between the cylinders, is this the water jacket? There are several bolts around the perimeter, and what looks like a gasket, this is the the area where the pee line comes out. I shut it down and checked the bolts, several were loose, a couple were very loose. Tightened them up and fired it up again. No more leaking. Should I worry about replacing the gasket? Or just keep an eye on it next year?
