1998 90 hp Johnston
Woggy
I recently purchased a boat with a 90 hp outboard and I cannot find the discharge hole for the impelled. Can anyone tell me where the the water comes out from the impelled so I can check that everything is working properly .
Honorary Supreme Mariner
You can not find the wee hose on the back of the motor ?----It goes to a fitting on the back of the lower cowling , starboard side.-------It indicates that the pump is working.-----It does NOT indicate that motor is cooling properly.------You should install a new impeller now.
