1998 9.9 mercury outboard
garnbill
hi i have a 9.9 2 stroke and i have milky oil well i drained the lower oil and it was pretty milky but there was no metal shavings on the oil bolt i only used it once this summer so i took the prop off and now im stuck i dont know how to get that big sleeve/ thingy off Im pretty sure I need to replace my seals in the lower end is this something someone that is pretty mechanical can do step by steps would be great!
shimano
Re: 1998 9.9 mercury outboard
You should pressure test to see where it is leaking .It could also be a seal somewhere else(water pump,shift shaft).
Mi duckdown
Purchase an OEM Merc manual for that motor. It will show you everything you need to know, and do. A merc dealer can order it for you. I think you can purchase one thru mercury online. got to have serial number.
