1998 9.9 buzzing sound
Matt Lyons
When I put the motor in nuetral, it makes a buzzing sound. I can't tell where the noise is coming from and it's not like a bearing going out. When shifted to forward or reverse the noise goes away. The motor runs fine any other time. Any suggestions?<br />Thanks
G DANE
Re: 1998 9.9 buzzing sound
Try to hold on the hood when you hear the sound. When in gear the motor lays force on the rubber mounts and vibrates less. Another possibility would be a loose mount.
Solittle
Do you have a remote gear shift/throttle? I'm thinking that the linkage may be off a tad.
