1998 75 hp Mercury
Flipperboat
While running on plane for about 4 minutes the engine starts skipping and spuddering. When I pull it back to idle it idles fine. Then it will jump right up on plane again and take off for another 4 minutes. I'm at a loss. Idles fine, cranks fine runs full blast and just starts skipping. I checked the fuel bulb and made sure I pumped it when it started sputtering no change. Any ideas what I could check?
Iceman66
Re: 1998 75 hp Mercury
Check your air inlet vent at fuel-tank, and all your fuel hoses and connecters.
alldodge
Could be the pickup tube in the tank is clogging, or fuel pump is getting weak
