1998 75 hp Force performance question
18 Angler
I have a 1998 75 hp force. I want to know what is the difference between the 75 and 90 horse models. They have the same bore and stroke. The 90 has .1 cubic inch more displacement. I had my carb off cleaning it last year and noticed what looked to be some type of restricter plate. Does anyone know if that is a restricter plate and can I remove it. The 90 horse uses a different spark plug which I believe is just a hotter plug. Does anyone know if this will increase performance and what adjustments may I also have to do. The timing and rpms for both motors are also the same. Any input would be appreciated. Thanks Bob
roscoe
Re: 1998 75 hp Force performance question
The 90 hp has 3 carbs, and sucks more gas.
It has a different gearcase and spins a bigger prop too.
That "restrictor plate" in the intake is designed to swirl the air/fuel mixture and distribute the fuel to all three cylinders.
Cylinder exhaust porting is likely different too.
18 Angler
Thanks for that info , that answers my questio. Now I have another one. I am looking to get a little more top end. Can I gain some more speed by changing my prop. Currently my prop is a 10-3/8, 13 pitch. At wot I am running about 5000 rpm. at about 26 mph. My boat is an 18' center console.
roscoe
You will probably be able to pick up 2-3 mph with a 11p prop. Better results if you go to a more efficient stainless steel prop.
18 Angler
Can I use a bigger prop also and what will that do for me? I have about an inch and a half bfore it will hit the housing. How about a prop like A Hustler prop? I was on a few web sites looking at props and read a few testimonials from supposed people who bought a Hustler prop and increased top end by 7-10 mph. Do you think gains like this are possible? Thanks Bob
