1998 70 HP Johnson 4-stroke Outboard Tach Not working.
akrobbob
I just purchased this outboard with about three hrs on the engine. The tach worked fine the first couple of hours of running then had the boat idling and tach moved very erratic now points straight down at 6 O'Clock. This is an OMC tach and the safety lights on the tach lightup when engine is first started, and the tach does move a bit but no response on the tach when running or in high idle. I have checked continuity from the controls back to the engine and that is fine, i have checked to see if it is charging the battery while running and it is, i have also tried another working OMC tach and it reacts the same way. Needing help on what and where to troubleshoot next. Thank you
