1998 60hp Evinrude strange starting phenom.
joebologna
Hello all,<br />Have been having a tough time starting my 98 60hp Evinrude, starts then quickly dies..suspected fuel so I pulled and rebuilt carbs. No luck, same problem. However I noticed this evening that it will start & run as long as the key is held in the start posit. As soon as you release key from start to run, it dies. Simple key switch replacement or something more sinister? Any thoughts or ideas apprediated. Joe Bologna @ Ky lake
rickdb1boat
Re: 1998 60hp Evinrude strange starting phenom.
Replace switch first. Sounds real probable. Besides, it a cheap fix!
Dhadley
Most likely thats it. If you want to double check, disconnect the black/yellow wire and try again. If it stays running you have confirmed your diagnosis. It will not shut off with that wire disconnected so you will have to flood it (via the primer -- that will still work) to kill it.<br /><br />Good luck!
joebologna
Bought a new key switch today on the way home from work ($38). Put it in and wallah, beautiful music from under the cowl. Great and easy fix, just a little difficult to locate. Thanks for the thoughts, will be slaying crappie by Saturday. Hope everyone has a blessed and bountiful week. Joebologna @ KYLAKE
