1998 5.0 Mercruiser Alpha1 Can't identify loose part
WakeJunkie
My outdrive wouldn't shift into fwd or rev gear. Pulled the outdrive and found two of these inside the exhaust billow on the engine side of the shifter.
Can someone please identify these parts so I know what needs repair?
WakeJunkie
Thanks BT.
Where are they supposed to be located? I have the shop manual and still cant find them. You say old. I assume they are needed?
They are encased in rubber when in good shape. They get damaged when the engine is run without enough water to cool off the exhaust. When the rubber parts are burned off they fall out of the exhaust pipe behind the engine.
