1998 115hp Sarter/solanoid
Nards
Last season I replaced the starter only on my 98 Johnson 115 with a Sierra replacement and it worked great. So when it didn’t crank up rather than test it I put in a Sierra replacement solenoid but no go the starter was bad. So, this time put a new Factory Johnson starter in and at first started right up over and over but Now (after maybe 15 starts) the starter keeps spinning even when it’s running and I have to disconnect from the battery to stop it... I put in a new factory ignition after this and it worked ok 3 times then the same thing. Any suggestions? The yellow/red striped wire goes to the S terminal correct? I’m at my wits end!!.... thanks for any help, phil
Bosunsmate
Sounds like the still running starter may have ruined the sierra one.
Perhaps your key switch has a short.
Yes S is correct. Perhaps you should put in a manual override switch on the starter wire
Carefully inspect wiring harness.----Could be a short circuit.--Any accessories hooked up to the motor control cable ?-----Starters last for season after season on motors that are well maintained and started with the correct procedure.
jakedaawg
Have battery load tested. Actually load tested, parts store will do it for free.
after that, with key in run position see if you have voltage at yel/red stripe small terminal of start solenoid.
