1998 115 hp Mariner will not rev over 2500 rpm
desotoboy
My 115 Mariner ran fine last year and this year it is acting up. It will start and run fair but when I open it up it will not run over 2500 rpm. When I turn on the key the buzzer sounds and after I start it, it stays on. Today, hooked to the hose, it would idle a little fast then cough and drop about 500 and then go back up. Help !
Chris1956
Re: 1998 115 hp Mariner will not rev over 2500 rpm
sounds like a compression test and a spark test are in order. Are you running the oil injection system? What does the alarm mean? Overheat?
desotoboy
I am running the oil injection system that seems to work. The compression is good on all four cylinders and when I have it running on the hose and remove the plug wires one at a time, the top two make a big difference but the bottom two don't seem to effect the operation very much.
The bottom 2 cylinders do not operate the same as the top 2 cylinders when the motor is idling !!!---They do not produce power at idle !-----Part of the design of this motor.---You need to test for strong spark on all 4 cylinders.---Strong spark means it should jump a gap of 7/16" or more.----Before running it out on the lake you must confirm that carburetors are all clean.---Confirm that all 4 carburetors are opening fully too.
Faztbullet
Also check accelerator pump and injectors....
desotoboy
Thanks so much for the info. I will check the spark and the carbs and probably have to have them cleaned. I appreciate The help Gentlemen.
