Re: 1998 115 Evinrude Won't Start
Daselbee,
Thanks for the offer and I will take you up on that! I will PM you, I've been working and have not had a chance to check for updates. It will be a while though, next scheduled day off is not until 9/21.. On the Opti, I figured if I was going to do the pack I would do the Opti anyway. In the end my boys will be using this more than me so I want to be sure they don't get stuck.. I will monitor my post more frequently, I did order more parts, anyway.. not going to sweat it.
Multimech,
Thanks for the advice, I thought be best to stick with BRP. I've not checked the stator yet. I will read up on it in the evening.
The OIS ingnition system is pretty simple really. I am with Daselbee about the sensor. I have always replaced them as a unit, sensor and pack. You can get spurious readings from them if you are not careful, from stray light when you have the cover off the sensor assembly. Hope you checked the stator, but from my experience the stator is NEVER the problem on these engines.
My money is on BRP rather than CDI, that was until BRP starting using CDI stuff on there engines. Go figure.
I would take Daselbee up on his offer. He can throw the parts on to check the ignition and replace only what needs to be replaced.
Daselbee,
Multimech,
