jbaseball33
Thread starter- Joined
- Apr 26, 2012
- 14
OK so the joy of buying the boat is over and now a issue/s(minor or major, not sure). The motor won't stay running at idle (stalls) and very little power underway, not fast at all, barely gets on plane and with my wife and kids barely hit 10mph. When we lake tested it was fine now it's not(stalled a couple of times). Pretty sure boat has been sitting awhile, might need carbs cleaned but not gonna be my first option
Few things I noticed -
1. The fuel bulb won't stay hard, it should right?
2. seems like it's miss firing
3. a rubber line from the oil tank(engine mounted) has a 3way valve that isn't connected on one side, don't see any lines not connected, is that for vacuum?
Things done after issue - replaced fuel line from tank to bulb, replaced fuel filter, still stalls and now no water out the back even at WOT
Here's what I've got -
1997 Mercury 150XR6, with 3 carbs
compression on all cylinders are 130#
Plug wires check good, all fuel lines inside motor look good
will stay running as long as throttle is half way
Things I'm gonna do -
1. replace bulb and fuel line to engine (bulb should be hard and stay hard?)
2. check water pump again
3. check spark in all cylinders(not sure on how to do it, w/o getting shocked)
ALL HELP APPRECIATED
