1997 V/P 4.3GLPLKD or OMC 432BPLKD with cobra SX drive
Following users manual for winterization, had a couple of questions. Boat stored outside in TN slightly bow high and tilted slightly starboard.
1. Pivot Housing Drain. Drive unit stored down. Tilted up (manual said) took off water drain plug (aluminum screw) on port side, no water, tilted down (manual said) no water. Cleaned out white powdery stuff from drain till got to something colored/painted black, still no water. I cant get water to come out of this hole!
2. Manual says drain Oil Coolers by removing the water hose from the oil cooler. I can't find oil cooler!
Have already drained:
Large hose at water pump on block.
Both cylinder block plugs with screw poked into holes (lots more water left after using screw to loosen debris/rust).
Both manifold hoses.
Both hoses on lower starboard water pump and turned engine over a couple of seconds.
Thanks
Chris
Thanks
Chris
