sscavanaugh
Thread starter- Joined
- Apr 25, 2015
- 1
I have a 1997 Johnson 90hp and the tilt trim does not work properly. The tilt/trim will go up a short distance and stop - I wait 10-15 seconds and it goes a short distance and stops again, it goes down in the same mannor. I replaced the relays, I recently replaced the tilt/trim unit with a used one, it worked fine for a few times before acting up. I have put in fluid but it continues to work the same and this problem occurs if I use the switch on the handle or the switch on the motor.
Any ideas what may be causing this? Thanks in advance for any/all ideas.
