1997 S200 Throttle Cam adjustment
Reming870
I have been having an issue with sputtering on the engine. i decided to take advantage of some fishing downtime and clean up the carbs. In the process, the middle carb adjustment screw for cam roller came loose. This screw is reverse thread and appears to hold a plastic roller which sits on a cam.
I cannot find any information for adjusting this. Can anyone help?
This roller and cam are on the starboard side of the motor behind the middle carb idle screw and the cam has an arrow indicator on it.
1997 S200TXRV carburetor
