1997 OceanPro 200 Intermittent Starting Issues
JimInSWF
Last month I purchased a '97 Wellcraft 23Excell with a '97 OP 200hp. On the initial sea trial, all seemed ok. It was a bit hard to start, but by using what I've heard of as "the quick start method" (pumping bulb until hard, then pressing in the key for ~10 seconds before cranking) it started and ran fine. Since then, even after running for some time, once turned off I have a hard time getting it to keep running when I restart. It will fire up and idle at ~1000rpm for 3 to 5 seconds then die. I can do this over and over for anywhere from 3 to 30 times. I've tried pumping the bulb when it is running, still dies, no difference. I've tried upping the throttle, out of gear, when running and it just seems to make it stall out quicker. I'll do this over and over again, then for no particular reason I'll throw it into gear when it first starts, like I've done 10 to 15 times before during this starting attempt, and she'll take off like all is well. I can slow to idle, and all seems well, speed up just fine, you wouldn't even know I thought for sure my batteries were going to die and I was going to need a tow service. I can drive around for an hour, all seems well, until I shut her down for even just a few minutes, and I'm back to the same issue. I'm new to the SWF Gulf boating (originally from MN) , and it really raises the anxiety level when every time you stop miles out at sea to fish, you have to really wonder how hard (or if) it will start again. Please help ! Any suggestions greatly appreciated !
Honorary Supreme Mariner
The key MUST be held pushed in while cranking it over for starting.
JimInSWF
I do that. It will start, run fine for a few seconds, then stall. Over and over again.
You may have to push the key in a bit after it starts to keep it from stalling.-----I believe the motor should have an electronic feature called " quick start " and is that working ?
oldboat1
off subject -- but not completely. You will get it running, but might think about a trolling motor if you don't have one. Maybe a 15 -- good trolling and get-me-home motor. If you get the kicker, it's almost a given that the big motor will run fine.
jakedaawg
Funny how that seems to happen.
Are your fuel lines all old and hard and weather checked? Is there a spin on fuel/water separator and have you changed it?
Chris1956
That motor should have the "Quickstart" feature. Quickstart will advance the timing to cause the motor to run at about 1200 RPM, until she is warmed up. RPM will then return to about 850 or so. You may need to hold the key in initially, for a few seconds, until the motor is warm enough for Quickstart to take over.
Quickstart also operates for a few seconds, each time you start the motor after it is warm.
It sounds like you should start checking your carbs for dirt and idle mixture adjustment.
dingbat
I have the same motor. Not the easiest motor to start when cold. but your on the right track
Your cold start procedure is the same I use. Don't be afraid to choke it (push in key) to keep it running when cold.
You're restart issue is something else. Once warm, mine starts with the turn of the key it.
Check to make sure your primer circuit isn't leaking past the seal. Check to make sure your shift switch is properly adjusted. Check to make sure your carb floats are set to the proper level. I've had issue with all three in the past.
JimInSWF
racerone - Thanks ! I'm not sure how to check if the "Quick Start" is working, is that something a mechanic would have to determine, or do I just watch the tach to see if she drops from ~1200 to ~850 after warming up ?
oldboat1 - LOL ! Ain't that the truth ! and a good idea for sure....
All - Coming from the frozen North in MN, I might be a little confused about "Cold" starting. I'm down in South West Florida now and it is usually near 80 degrees out when I'm boating. Sitting in the sun, I'd guess the motor itself is over that even if it is painted white. Is this still "cold starting" ? I suppose for an engine it may be. I'm just used to starting my '84 Force 85hp in 35 degree weather. Then you need a choke !
dingbat - just got done checking all the fuel lines, water separater and pulled the air intake cover. All carbs "look" nice and clean, but when I had it off I climbed aboard and pushed the key in and nothing seems to happen. On my Force 85, there's an audible click as the choke is closed, but here I don't see or hear anything. On this motor what is the "key push" supposed to do ? Is there anything I should be able to detect ?
Thank you all so much !
jakedaawg
When you push the key in it activates the primer solenoid. It's quiet, not like an old choke plate that you can hear.
JimInSWF
jakedaawg - Thanks, but I was really hoping I found a problem. Everything I keep checking out all seems to be working properly.
I'm guessing I can check to see that the primer solenoid gets 12V when the key is pushed, but do you know of a way I can test to see that it is working if I can't hear anything ? Possibly pumping the primer ball until firm, then pushinh key and see if the line pressure drops (faster than when not pushing) ?
JimInSWF
I'm guessing I can check to see that the primer solenoid gets 12V when the key is pushed, but do you know of a way I can test to see that it is working if I can't hear anything ? Possibly pumping the primer ball until firm, then pushing key and see if the line pressure drops (faster than when not pushing) ?
sutor623
Yup easy to check. Once the motor is idling well and warmed up, push the key in and hold it down to see if the idle drops or the motor studders and stalls. If the motor wont start you can try another method. Prime the bulb, disconnect one of the primer fuel lines(leave it connected to the primer solenoid, and disonnect it from the engine side) then put the hose in a 20oz bottle or glass jar. Go to the controls, push and hold the key in, turn the starter over for a few seconds, and see if fuel is in the bottle.
dingbat
You can hear the primer solenoid click, but the bigger problem is it sticking open (flooding) or leaking at the selector lever (air in fuel supply). Keep pressure on the primer ball and inspect for leakage past valve. In reality, there isn't a choke , per say. Raw fuel in dumped directly into the cylinders
A motor operates in the 140 to 160 degree range. 80 degree is "cold".
Quickstart drops out when the head temp reaches 95 degrees. Doesn't take but a couple of seconds to reach that temp. Even in cold water, it doesn't take but 5-10 seconds to disengage. The rpm drop is noticeable (200-300 rpm) when QS drops out.
Did you clean the idle ports under the little plates on the side of the throttle bodies? Fought that battle this Spring
oldboat1
If a get-me-home motor can reduce anxiety (did for me), basic maintenance can too. In salt water use, it's going to be important to wash down and flush. If you're not sure when the impeller was replaced, need to do that. If you are outside of the temp range, also suspect salt build up in the passages and t.stats. Guessing, would say you might have open or sticking stats (might be running cold). Thinking you might not have a working temp gauge -- good to have one.
