reef donkey
Thread starter- Joined
- Mar 17, 2011
- 8
I have a 1997 Evinrude Ocean pro 175hp that will idle fine when cold. When i run the boat 30 min to an hour turn the motor off for an hour it will start right up put it in gear it will go dead get it to 1/4 throttle it will run fine. let it set for 3 or 4 hours and it will start up and run fine. This has me puzzled that it only does this after it gets hot. It will run all day if you don't turn it off. I have changed the fuel line, water seperators, vacuum lines, coil and plug wires, and spark plug. My thinking is if it was the carbs it would do this hot or cold. Now i am pointing to the power pack. Has anyone had this happen to them if not..do you have any suggestions . THANKS
