Johnson110
Thread starter- Joined
- Dec 31, 2003
- 640
I have this motor with oil injection hooked up, being the age of the motor 1997 is it still ok to use? motor never overheated and does run good. Thanks for any replies!
No I have been using it for a couple of years now, I add some oil to the first gas for the start-up but then go to straight gas after that is used up I marked the oil tank and it does drop. I once bleed the oil pump and it has been working, It just a old engine and I was wandering the longevity of the oil injection system.
I recently replaced a 1983 Johnson 115 hp that had the oil injection disabled. I bought a 1990 Mariner 115 and asked the mechanic about disabling the oil injection he explained that Mercury uses a gear driven injection pump vs OMC's bellow driven pump and is much more reliable.
In all my years of boating, I have used " Pennzoil" 2 cycle oil with great sucess. Never had a engine issue or plug fouling issue. In my younger days I worked part time for a local marine mechanic and he swore by Pennzoil and I guess it just stuck with me. I did see that the TCW3 is for premix or injection systems. When I bought my new to me used Merc oil injected motor I ask him what oil he has been using...showed me his bottle of Pennzoil TCW3......cant argue with sucess !!I always run injection 2 cycle rather than just any 2 cycle oil.
