1997 Merc 4.3 V6 LXGen+
Proover
When I grab my distributer by the cap, I can turn it counter clockwise bout 1/4 inch. I can turn it back (clockwise) the 1/4 inch. I've loosened no bolt or screw. Is this a normal boat/marine feature? Is it an automatic timing advance feature governed by performance loading?
In my distant past with car engines, I never found this feature on any engine.
FYI - I'm a complete novice with boat/marine issues.
Lou C
Nope. Is the whole distributor moving or just the cap?
The cap is screwed into the distributor and the distributor is clamped to the intake manifold.
Scott06
As lou said this isn't normal most likely the hold down clamp for distributor is loose. Set the timing with a timing light and tighten clamp.
I believe you will have thunderbolt ignition which needs to be put into base mode to set timing
Proover
The whole distributer is moving.
Proover
And yup...I suspected it isn't normal. I'll have to contort myself & blindly fish around for the hold down clamp.
And thanks (you & Lou) for the feedback.
Lou C
You need a crowfoot wrench to get at it, I still have one I bought back in the '70s, it's in 2 pieces, one side is for Chevrolet and the other side is for Ford. The hold down bolt is right behind the carb between the carb and the distributor on the left side as you face it from the front. Keep in mind that now you have to find out how to set the timing, that's what is changing when the distributor moves. It must be set to spec.
Scott06
I've used wobble extensions and home bent wrenches as well...
Proover
I'll get it done but, the boat has been running and not bad at that...with the "floating" distributor. I've run it several times this season. I changed the fuel filter/ water separator and it started right up & ran fine. Then? It just decided to not start. We've "freshened" all that we can with fluids & ignition. Ran it all last season (until a wheel flew off the trailer) then winterized it.
Bottom line? As with many boats, it's a project. Fix/upgrade one thing & a new mystery appears.
Thanks for your support. I'll be back...I'm sure.
Proover
Well, with new coil...nuttin. now, we'll check for spark & fuel flow.
FYI...my old coil wire...connector was packed with gunk. Didn't seem to be grease. Was soft malleable gunk. I cleaned it out. Was this a mistake? Is the coil end connector purposefully packed with some sort of conductivity "gunk"?
dubs283
FYI...my old coil wire...connector was packed with gunk. Didn't seem t o be grease. Was soft malleable gunk. I cleaned it out. Was this a mistake? Is the coil end connector purposefully packed with some sort of conductivity "gunk"?
Older oem thunderbolt systems used a paste on the coil tower to prevent arching to the primary sides. Is okay to remove or leave in place
Newer styles are better sealed boots and don't need the paste
Proover
First time I've seen a coil replacement as a fix for a loose distributer...
Not at all what's intended. It's just another guess re: non op. Old coil was 1997 vintage. 25 yrs old. Didn't fix it. Distributor is in original operating position. Twisting is met with resistance. It doesn't twist loosely.
dubs283
Still no spark situation? First WAG on a t bolt system is ignition sensor in the distributor.
There is a thunderbolt troubleshooting guide in the stickies, top of forum page.
Scott06
Shift interrupt activated ? Try disconnecting see if it rolls
Proover
?Well, in our first novice attempt...no spark. We traced it back to the Ignition Control Module. Circuit is energized + on coil to ground on manifold; No energy + on coil to - on coil. Indicative of dead coil (it's brand new). No energy coil + to ground (gray wire) at ICM. Next? Find a 807829-1 or conversion 861251A1. Not on this planet apparently. & It would cost $600+.
Anyone have one kicking around would let it go?
Question ;- how can I test the module to assure it's nonop...or not? While I wait, gonna repeat & concentrate on potential wire compromised.
Proover
