1997 Merc 175 - Trim/tilt only goes up
jeswans
I am having an issue where the trim/tilt using either the control switch or the swith on the engine only actives the engine up. When you press either swithc to lower the engine, nothing happens?
any thoughts or someone have a similar experience ?
Thanks
Barnacle_Bill
Re: 1997 Merc 175 - Trim/tilt only goes up
Swap the relays and see if the problem follows.
