1997 Merc 150 XRi
Scotthorn
I have a 1997 merc 150 XRi. It has run seamlessly for the last 6 years since I purchased it. I always fill the tank and put additive in the fall, and give it a shot of Sea-foam in the spring. This summer when I put boat in water it won't maintain a consistent speed at higher range. My rev's go up so far and it holds. Everyone once in awhile it lunges forward and down. I have always run premium fuel and did nothing out of the ordinary in storage last year. The lunges are intermittent and when it does only for a second then bacl down. Any ideas??
Chris1956
Re: 1997 Merc 150 XRi
Check the fuel filters for clogs, the fuel lines for air leaks and the antisiphon valve for clogs.
Scotthorn
Thanks for the options. I will go over everything you mentioned. I checked the fuel lines already with no sings of leaking. I also checked the fuel filter, but i have a week at cabin starting the ninth. I'll start at the tank and work my way through.
Thanks again
Scott
