1997 LARSON RUNABOUT 4.3L PENTA 186 SEI NO POWER AT COIL
Fubarredgoat
Banned
I HAVE A 1997 LARSON RUNABOUT WITH A 4.,3 L VOLVO PENTA ENGINE.. I HAVE NO POWER AT THE COIL. I CHECKED UNDER THE DASH I HAVE POWER AT THE KEY BUT NOTHING IN THE BACK AT THE MAIN BOX.. WHEN I LOOK AT THE FUSE BOX I HAVE A 20 AMP FUSE WITH NO LEADS CONNECTED TO IT. IS THERE A SITE I CAN GET THE WIRING DIAGRAM FOR THE FUSE BOX?
alldodge
Howdy
Probably needs to be in the VP area but until a Mod moves it I'll offer this as a non-VP expert.
The most common cause for no power to the coil is the kill switch. Power comes from the key switch thru the kill switch and then to the motor. So if you have power at the key, and also to the wire feeding the motor, but it doesn't make it to the motor, check the kill switch and then the engine main harness connector
