1997 johnson 3 cyl
my son took the boat out today first time this spring,said it ran well for 15 minutes. then started missing got it back home no comp on #2 cyl what should I loo for
. Never took apart a outboard before. any help thanks ron
flyingscott
Kind of a common issue with them if you are sure the compression is 0 time to pull the head
tblshur
juststartingout , if you shure of comp , my guess is you will have to pull head and have a look hopefully just a head gasket. it just a guess so wait for someone with more knowledge than me to chime in, good luck :joyous:
emdsapmgr
A faulty seal ring on the #2 hole in the head gasket would make an easy and cheap fix. If it's more that than, you are looking at a powerhead teardown and at least a partial overhaul. At this point, you need to be working from a genuine factory service manual. Check out this website: outboardbooks.com
I will have to go back to where the boat is now.get pics the gasket look good no score on the wall I am a mechanic by trade but never worked on 2 stroke
Crosbyman
I would check that head gasket real close..:cold: . I have replaced them on a JW and a couple 4hp
Crosbyman
well since you opened it up I would change the (cheap) head gasket* good or not...
check the head for flatness with a steel ruler or piece of glass looking sideways.
if you see light ...it is warped.. you need to resurface it
* get the good OMC stuff
flyingscott
There are access covers on the side of the motor by the electrical panel you can remove those to see the side of the piston.
Honorary Supreme Mariner
I do not believe there are any covers on the side of the block to look at the pistons and rings !
