1997 Johnson 225 venom
Stratos201Elite225Jonhson
I have a 225 Johnson that is acting crazy I have compression check and traced all of the fuels lines "they are good" and I have adjusted carbs but it still won't idle the only time I can get it to run in the water is tilt it all the way almost out of the water and open the throttle all the way open and when it does pop off it smokes really really bad. I have done all I can think of to it and it won't crank on it own only with throttle all the way open and wont idle but will scream like a scalded cat at full speed but lungs really bad until it hits 3000 rpms........ Somebody please help me!!!!!!!!! I tired of messing with it...... I took the thermostats off to look and reinstalled them and it cranked and idled like it suppost too and then the same problem the next day.....
daselbee
Allright.....allright.....you have been advised to get a compression test done, as well as a spark test done, I am sure.
So please post the results of those two tests. "Compression is good" is an unacceptable answer.
In the meantime, as you are trying to start it, and as you are trying to get it up to WOT, press the key in as needed.
In other words, if you feather the key (choke) pressing, releasing, pressing, releasing, and the engine picks up, it could very well be indicating a badly clogged idle and midrange fuel circuits in the carbs. Another thing you can do is to turn the red lever on the primer solenoid toward the OPEN position, but not all the way.
Just open it enough to let a bit of gas thru, enough to cover the deficient fuel from the carbs.
I had the same problem, and by feathering the key/choke, I consistently was able to get it up to speed.
So....what to do. First of all, look up by searching my username and the word "throttlebody" "throttle bodies" etc...read up, and get back here with questions.
I am awaiting the results of the two tests until then.....
I did the compression check again to be completely sure they were all six between 100 and 110. I had the crabs rebuilt about a month ago and it ran fine while the guy had it I went with him as he was finishing it up and the hot foot came loose. It took me a couple of days to get to it to fix it and got it back jn place and took it to the lake to try it out and it started doing the same thing it was doing before I had the carbs rebuilt. I did a spark test and they were good as you could them popping. But you can let try and crank it and it won't even try to start but you can let it sit for a couple of hours and go out there and it will pop right off and idle for about 15 seconds and die then won't pop off anymore till you let it sit for a couple of more hours
Fed
From your other thread (bad idea starting a new one) you mentioned the primer valve is in the open position?
It should be in the closed position and only open when energised.
Ok got a new symptom now I have a leave I guess it's coming from behind the intake and it is running down the linkage behind the intake..... How do I fix this? I also was checking my primer bulb to see if it was bad and I could pump fuel into the filter and it would get hard but could watch the fuel pleed out of the filter I always thought that once the filter is full it should stay full through out the running of the motor and would eventually leak down once done running. I guess I'm sucking air from somewhere........... Somebody please help me!!!!!
