1997 Johnson 115hp outboard
Bholub36
Distance from mounting surface to top of driveshaft is...21 3/8
dkstance from mounting surface to hole in shift rod...21 1/2
Bholub36
In the research i have done, i have found the 60 degree looper v4 95-2003 showing 21 1/4. Which if thats correct...that would mean i would have to thread my shift rod in therefore engaging the forward farther when installed?
Bholub36
One further question. It appears i found that measurement and didnt notice that it was for a 20in shaft. Im pretty sure mine is not a short shaft. How do i figure out what length driveshaft my outboard is so i can try to find the correct measurement?
They did not market that motor as a " short shaft "----Your model # has the information you need.------The " shaft length " does not refer to the actual length of the driveshaft.
Bholub36
Got it back together. Shift arm is vertical to crank case. Everything seems much better. Water test to come wednesday. I truly appreciate all of your help!! Will post results
