1997 Johnson 115 SPL Air Starved
Chip884
Have a 1997 Johnson 115 SPL that runs fine at WOT so long as one of the engine cover locks is left unsecured. As soon as I secure all the locks it won't get up to max RPM at WOT. As such, sounds like it's having an air starvation or some other issue. Any ideas as where to start the trouble shooting process?
jakedaawg
Route the bottom spark plug wires more carefully. One or both are grounding on the latches. Known issue, easy to resolve.
Chip884
Believe your assessment is correct! Pulled the cover and found a faulty spark plug wire that definitely could be grounding out on the latch. Easy fix.
Chip884
Determined the fastener that connects the port side locking hook to the cover is touching the spark plug wire where it connects to the bottom coil. Engine vibration causes the bolt to rub and pierce the rubber insulation and ground-out the cylinder. Going to explore using a different fastener with a lower profile for the cover hook.
Honorary Supreme Mariner
Perhaps the clamps that hold plug wires away from latches are missing.--Common problem as you have found out.
