After having issues on the water last weekend, followed by replacing the power pack, coil (again), spark plugs, throttle roller, timing roller, and primer fuel lines...
I'm having issues with timing. I went through the manual, and reset the short spark control rod to 2.5" length according to the manual (2 1/2" for models equipped with a 12 amp charging system or 2" for models equipped with a 4 amp charghing system). It was set to 2.25" (the shortest it will go). To accomplish this, I also needed to adjust all the linkages, reset the carburetor WOT setting, etc.
You may be able to see from the picture that the spark control rod wants to be much shorter than 2.5". In this image, it's at its shortest adjustable length of 2.25" between post centers.
If I connect the spark control rod, it backfires and dies. Do I need to go to a different spark control rod? I'm looking at part numbers 334153 and 435530 and these are what I think I have.
Do I need to reset everything? If yes, how do I set the initial linkage without crushing the timing roller? Are the arrows for the timing roller just there for aesthetics, or do I read correctly that it should be between them when the engine is at idle?
Photo of linkage as-of now with throttle closed:
-- DW
- Both carburetors are currently bench balanced
- The WOT limiter is set at wide-open throttle
- I reset the timing retard stop to prevent crushing the timing roller again.
-- DW
