1997 intruder 175 WOT issue. Not revving
Davep199524
Recently got my intruder in the water and have been having an issue with the engine not getting revs. Will rev to about 3900 on the tach and the engine is sluggish to get going out of the hole... it’s also not wanting to idle at the normal 700-800 it kicks and dies out.. but isles fine if you bump the throttle to about 1000. Upon the basics I found that my primer bulb had some leaks as well but replaced with a brp bulb. As we as the o ring seal around the fuel filter on the vro appears to be pinched causing a possible fuel leak.. also noticed when the engine is primed and fully trimmed up the bottom two carbs leak gas into the cowel. Any help would be appreciated if anyone else has had the same issue I’ve heard it can be the power pack but now after some diag I’m wondering if the fuel leaks could be the culprit
