I have a '97 Force ( 50HP )that hesitates or has a slight miss at full throttle and will quit missing when I let off the throttle. It will run about 5200 RPM at full throttle and drop a couple RPM during the miss. I am not sure how to check the coils, the plug has 4 pin connector that plugs into the coil and I ohmed out the coils and compared readings between the coils and it has the same readings. I have replaced the fuel line. Cleaned out the carburator. Not sure what else to check. How can I check the stator? I am not sure if it is a related problem, but I only had to charge my cranking battery every once in a while and now I have to charge every time I am taking the boat out. Any help would be apprecaited.....
