1997 Force 90 bendix gear not engaging
CZSteve
We just pulled our toon off the water for cleaning and moving to a new marina.
Started fine last week but now I tried cranking and the starter bendix gear does not engage with the flywheel. The starter will spin the bendix but it does not extend and engage the flywheel; I can spin the gear by hand, does not seem to be corroded.
We put a new starter on about 14 months ago; never changed the solenoid but I do have a new one if needed.
- Sound like a bad starter again?
- Bad solenoid be the culprit? (Didn't think the starter would turn if the solenoid was bad).
- Relays? (both relays 'look' good but original).
EDIT: I just manually raised the bendix gear into the flywheel teeth to see what would happen.
- As mentioned, bendix gear moves fine on shaft.
- When tried starting the starter did not turn-over; just made a buzzing sound and now the bendix gear won't come back down.
What does this tell you?
(batteries should be fine; one primary for starting & one deep cycle for radio - on a perco switch).
Thanks again,
Steve
Barnacle_Bill
Re: 1997 Force 90 bendix gear not engaging
Check your starting battery and all connections.
jerryjerry05
Load test the batteries.
Then do a compression test.
Compression /spark test is the first step in diagnosing any starting problem.
The starter worm gear, a touch of grease.
The solenoid could be bad.Weak.
The starter take it apart.Even fairly new can go bad.One bad brush or a loose magnet can cause that.
The bendix is supposed to release when the motor goes faster than the starter.Again some grease.
CZSteve
Well H3ll....
Yup, starting battery connection needed some cleaning; there was very slight corrosion on the negative terminal - wouldn't have thought it was enough to make a difference but apparently it was.
Thanks,
SA
