1997 force 120 pee-hole problem
scottnjay
Hi, I am new to the boating world. My 97 force 120 will put out water from the pee hole for about 20 seconds when I start it up with the muffs on and then quit. Of course I get worried after about 5 seconds and shut it off. I wait about 15 seconds and then start it up and water comes out again for about 20 seconds. It just started doing this on the lake too. When I am cruising with any speed it is fine, but as soon as I just idle it shuts off after a little while. I just bought it used so I am planning on replacing the impellor just in case, but I don't have time for a couple weeks. Is this normal or should I just hold off on using it until I can replace the impellor? I was thinking it maybe has a thermstat. Water shoots out of the bottom unit from several places when the muffs are on. I don't know if it has an overheat alarm, I freak out and shut it off too fast to find out. I plan on getting a manual, but that will take a while too. (waiting for payday)
roscoe
Re: 1997 force 120 pee-hole problem
Replace impeller before using it.<br />Those engines can be seriously damaged by overheating.<br /><br />If you have time to use the boat, you have time to change the impeller.
