1997 evinrude priming solenoid question
Denny1
I have looked at a lot of the discussions pertaining to the priming solenoid but I still have a few questions. Do all evinrudes that have the solenoid make the clicking noise when key pushed in? Mine does not. I do have power to the purple wire tho. Also should my motor bog down once running if I push in the key and hold it in as mine I see no difference. I haven't had any issues starting recently but I want to make sure the solenoid is working properly as it gets colder for duck hunting season. The manual valve red lever does work but I'd like to keep that for use in only desperate situations. Thanks guys
joeanna
you may be able to hear it click depending on how your hearing is. if the motor is warm/hot= using the choke should/will bog and/or shut engine down,. if the key choke doesn't operate the choke, use the manual red lever, if that doesn't do anything, check the fuel supply and inspect the plunger. My plunger was extremely tight fitting and needed to be loosened for it to operate, Also, with an amp meter mine used about 2 amps while in use.
interalian
They make a hollow "tock" sound. If you have 12V on the wire to the solenoid and a good ground, chances the solenoid is bad. You could measure between the two wires with an ohm meter - should measure around 10 ohms.
Honorary Supreme Mariner
With motor running and key pushed in it should slow down if primer is working.----Perhaps plunger is jammed / clamp is too tight.----Might be an easy repair.
Joe Reeves
Engine NOT running! - The small hoses leading from the primer solenoid....... Disconnect one of them from the intake manifold or carburetor, whichever it's attached to. Pump the fuel primer bulb up hard. Now, with the key in the RUN position, push the key in while observing the end of that disconnected hose.
If fuel shoots out of it when you press the key in, it's functioning as it should and your hearing needs work! :)
jakedaawg
If you have 12V and still not working, first thing to check would be the ground, then post #6.
Denny1
Looks like the solenoid was bad. It had 12 volts. Ground looked good and still didn't work. I even took the solenoid apart, hit it with carb cleaner and still no good. I'm lucky it ran good not needing the times I used it. I'm going to replace it with the manual hand pump primer as it looks like it is meant for it just below the fuel hose connection point.. also for half the price. Anyone ever go from the electric option to the manual primer.? To be clear I have the e50tleuc model
bob johnson
that will suck..... you wont be able to prime from the control!!!....
Denny1
It rarely needs to be primed. engine runs great. it's just for super cold days during duck season if she's stubborn to turn over. The electric priming solenoid has not been working since I bought it I just found out. It looks like it hooks up manually below the fuel hose hook up. Am I correct with that ?
