1997 Evinrude on 1995 Sunbird boat
Pologreen
Hi guys,
Newbie poster who has done lots of reading on the forum and thoroughly enjoy all the discussion, advice and helpful tips that get shared. While I've read lots of posts related to my question, and learned quite a bit, there's a few things that remain unanswered that I'm hoping you can help with.
Last summer I had to replace my 1995 115hp Evinrude and I found a 1997 115hp Evinrude that I decided to replace it with. The guy I had bought the 1997 from had disconnected the VRO and was running per mix, which is what I did for most of last summer until the fall when the fuel pump portion of the VRO quit and needed to be replaced. So this winter I purchased I new VRO unit and decided I would hook the oil injection back up (yes I know many of you will disagree with this decision:) ). So here is the question, this weekend I was installing the new VRO, but with the wiring harness adapter that was on the engine, I couldn't find a place to connect the two wire low oil wire that comes from the oil tank.
My first question is, is there a different adapter I might need that will have a lead where I can connect the low oil wire?
Second, given I don't have the System Check warning system because the boat is a1995, will the wiring harness that is in there now still provide warnings for, no oil and the other alarms like over heat and I think the other is restricted fuel flow?
Right now I am running the engine with pre mix in the tank and the new VRO connected, so it is likely getting over oiled (better than the alternative), but I'm hesitant to run straight gas until I can be assured that the warning systems should work. For instance, because the low oil lead is just sitting in the engine compartment not connected to anything right now, should I be hearing a warning from the beeper (which chirps on self test just fine)?
Can anyone provide any assurance that without the system check gauges I the warning system should still work for my 1997 engine as it is connected today.
Thanks for any insight you can provide, and sorry for the long post.
emdsapmgr
95 was the last year of the red plug connector between the control box and the engine. In 96, OMC went to the new deuch connectors. If you want to connect the newer system check gauges, you should be ok. Contact your local Evinrude dealer and read thru their Parts and Accessories guide-the Rigging section. Right after the Icon section.
Pologreen
Thanks for the reply emdsapmgr. I don't currently have the system check gauges and was hoping not to have to purchase them. So I'm wondering if the wiring harness adapter I have used will still send warning signals to the beeper system that was installed in the boat for the 1995 engine that came with it originally. Thanks again!
Pologreen
Hi guys, is anyone able to comment if the beeper warning system should still work for me. After further research it looks like the engine has part number 176349 on it but it might be missing the small wire for the low oil warning. I can live without that if all other warnings will work.
Many thanks!
