1997 evinrude 90 / tachometer question
caleb 777
I recently started a Wellcraft cneter console restoration. I have put a 1997 Evinrude motor and a new tach on the boat. The tach I adjusted this to 4 cyl and it also has a Pulse position as well. It seems it is registering a high rpm on the tach, should this tach be on set on the pulse setting and if so what setting. The tach is a Merc tach late model.
Re: 1997 evinrude 90 / tachometer question
You have a two-stroke outboard. As such the number of cylinders means nothing since the tach gets its signal from the charging system. Set the tach to the 6P (6 pulses/rev) which is created by the 12 pole alternator.
