1997 evinrude 40 hp tiller tilt assist
maineiac5586
Master Chief Petty Officer
Is there an alternative to the lever operated touch trim cylinder for my 97 evinrude 40 hp longshaft tiller ? It doesn't use the same bracket as a control equipped motor or else I'd think about adding a power trim unit.
tphoyt
I have heard that the 35hp rated unit will handle a 40hp 2 stroke but I would research that if interested. It’s a few $$$ less.
maineiac5586
That's why if you find the whole motor you get all the parts.
You think that whole bracket will swap over? I have a 48 hp longshaft parts motor but it's a regular controls motor and has the touch trim unit (non functional) . I wonder if I swap that bracket all I need is the power trim unit from another motor not a whole bracket
