1997 Evinrude 25hp starting problem *HELP*
cbj021chris
Have a 1997 Evinrude E25TELEUM tiller outboard. Cant get it to run for the life of me. Was on the water one day, seemed to be running bogged down and sputtery. Once turned off I couldn't get it started again. Have since replaced the fuel pump assy and spark seems good though I'll be rechecking that. Sprayed carb with cleaner, not sure if a problem with the carb. Primer bulb pumps firm and holds staying pressurized. Seems to get close on the electric start like it wants to turn over but never does.... Occasionally it seems to backfire/burst air through the muffle. Any help on this would be greatly appreciated... cant get it running for the life of me.
cbj021chris
Any way of checking the flywheel key for an issue without pulling the flywheel? Planning on getting to that this weekend. Have read about symptoms caused from sheared key that are similar to mine, also wondering if bad power pack or coil pack
cbj021chris
Will be doing that then tonight to check... Will message back with my findings. Hoping to not have to pull the flywheel but we'll see.
