1997 evinrude 200 hp stopped
Mfbartos@yahoo.com
My motor stopped I pulled the heads the port side had powered metal in the cylinder the cylinders look good and the motor does rotate now I turned the fly wheel by hand what could the powered metal be
boobie
To bad you didn't do a compression test on it before you pulled it down......
Mfbartos@yahoo.com
Could not do compression test the metal power would not let one piston to come to top dead center
How could skirt get past rings
Faztbullet
It really doesn't matter how as damage was done...its rebuild time. Do the water mod to block and replace all pistons ....
