1997 evinrude 115hp seized
lashley
Re: 1997 evinrude 115hp seized
I want to get a service repair manual. Bob says I need #507268. my model # is E115GLEUC and it's an evinrude intruder.I just want to be sure I'm getting the right one.I tried to call evinrude today, but only got a recording referring me to another source that does the service manuals. mine is a 1997 model, they only go back to 1999. is there another place where I can get the one I need? also, is mine a 60degree or a 90 degree?
bob johnson
get the one I told you, I have a 1997 motor as well as a 96 and a 95. your motor is a 60 degree V. the manual should be for 90 105, 115 150 and 175 hp motors...johnson or evinrude,...same manual
go to ebay.. they have them all the time
here, took me 5 minutes:
http://www.ebay.com/itm/1997-Evinru...anuals_Literature&hash=item27cb88d699&vxp=mtr
look at the third picture, youll see you motor listed!!!!!!!!!!!!
bob
lashley
got the motor running again. when you give it throttle, the fuel line runs out of gas . when you pump the bubble, it runs for a minute and then you have to pump the bubble again to keep it running . any suggestions. I checked in the service repair manual but couldn't find any answers.
ezmobee
Fuel tank not properly venting would be my first check. If that checks out, you may need a fuel pump rebuild.
trendsetter240
Could be the fuel pump or an air leak in the fuel system somewhere. Do you notice any fuel pooled inside the engine lower cover? If not, my guess is fuel pump.
