1997 evinrude 115 hp E115TSXEU needs carb kit
rfwj
I think it is time to rebuild my carbs on my 97 evinrude. Do you all have suggestions on where to buy a kit and what other items I should replace when it have the carbs out. Also a video link would be cool. I have watched the diy stuff for a larger engine. thanks. model number is listed above
emdsapmgr
You can look the carb kits up on the factory exploded parts list website: epc.brp.com
Chris1956
Honorary Supreme Mariner
Normally carb kits are avail from the OEM, Sierra, Mallory and others. They are retailed on many websites.
rfwj
Thanks. there is one carb per cylinder? i will do a video search
If the 2 float bowls are plastic they may well be warped.-----New ones are big ticket items.---------What is your motor doing / not doing that leads you to believe carburetor work is needed.---Any other trouble shooting done ?
rfwj
very hard to start. I have to remove air cover. open carbs and spray starting fluid in carb to start. once running and warm, it will start. seems like a air fuel mix at start.
Is the electric primer working?----The electric primer does what you are doing with the spray when you push the key in.---You push the key in while cranking the motor over.
rfwj
i hear it click when i push it in. in warm weather it does start with the 10 seconds then turn method but even that can be hit and miss.
Sorry, the key is to be pushed in and held in WHILE cranking the motor over !
