1997 90hp Johnson Ocean Runner V4 starting problems
rob750
Hello the other day i turned my boat on and it started fine. Then the next day i went to start it again and nothing happens. I try to use the tilt and trim on the motor and that does not work as well. I already check the battery and it is fine. I also got a test light to see if there was power to the starter and there is. Does anyone know what it might be ?
Chris1956
Re: 1997 90hp Johnson Ocean Runner V4 starting problems
There is likely a fuse near the starter solenoid. Check to see if it blew. If so, you have a short somewhere, you need to fix.
rob750
thanks ill check for that fuse today..
rob750
Does anyone have pics of where it is ??? I have looked everywhere and cant find it ...
