1997 80hp 2stroke rough idle
FLETCHxj
Just bought a boat with a 1997 2 stroke yamaha 80 horse. The boat starts right up but has a rough idle and appears to be running a little rich. Once you give it some throttle it smooths out and runs great. The previous owner said he had a mechanic that just went through everything and cleaned the carbs. He seemed like a honest guy and said that he thinks it may just need to be adjusted. Do y'all have any ideas of what may be causing this? Thanks
tommarvin
Ensign
When ever you buy a used outboard, you always do the following, clean the carbs and jets, install a spin on water separating filter, drain the LU gear oil, if there is water in gear oil, or bad/low compression you should not have bought the outboard, replace water pump,which is a hard rubber impeller on an outboard Rough idle could be a partial plugged jet, the idle air fuel mixture screw adjustment is screw it all the way in gently, then back it out what the Manuel says, its about one and a little more turns. 50-1 two stroke oil in gas, replace all on engine fuel filters, ,put thermostat in pan of cold water heat it up slowly what temp does it open ?
tommarvin
Ensign
Take the carb bowl off, get the largest drill bit that will fit in idle jet tube, gently clean it out.
