grasshopper45
Thread starter- Joined
- Jul 14, 2013
- 4
1997 40 hp mercury
It all started with, won't low idle. I have rebuilt the fuel pump and cleaned the carbs. Took a compression check and only has 80 psi. That is on all cylinders and they are all even. The motor really dose not have that many hours on it. Can't really check the timing because it will not idle. Question what is the trigger mechanism about. When I lift the lever to start it will take about 15-20 seconds to go into high idle. Hopefully someone will tell me it could be stuck rings or bad head gasket. Also is selco the best manual as I do not have the manual yet.
