1997 25hp Water Pump Replacement Problem
Cgunz757
I am attempting to change out the water pump with a replacement kit for my Johnsom 25 EEUB. I have removed the 4 bolts and nut connecting the lower and upper units, and I have removed the intake screens to access the shifter rod connection. I removed the lower brass nut separating the shift rod connection, but the upper nut will not slide up the upper shift rod revealing the plastic keeper to remove the upper nut. The motor has been used in saltwater so I'm not sure if the oxidizing has caused the nut to bond to the plastic or shift rod. Has anyone had this problem or have advice on how to resolve this problem?
Honorary Supreme Mariner
Paint on the upper rod will stop the nut.------Just clean it !
