1997 200hp oceanrunner trim/tilt problem
jatr24
hi all
im having a problem with my trim/tilt the motor runs from engine&throttle switch but nothing happens
iwas raising it and engine stopped going up but moter runs when button is pushed up or down and now engine is stuck 1/2 up
? is where is the oil resivoir /fill and do i need to remove the (c ring) before i loosen maunal down screw
thank you
boobie
Re: 1997 200hp oceanrunner trim/tilt problem
Back the manual release valve out no more than two turns and raise the mtr to full tilt. There is a cap on the reservoir on the starboard side, fill it and see what happens. If it starts working cycle it up and down 5 times and recheck oil level.
jatr24
update went back next day to work on it and now T.T motors does not run at all
checked every thing i could ? is can i hot wire 12v from battery to T.T to see if thats the proble
phillnjack2
Ensign
to use the release screw DO NOT take c-lip out. just turn the screw.
Once you have turned the screw you can just lift the leg from the very bottom of the skeg, its going to be heavy so be prepared with prop to keep it up.
the tilt reservoir cap might make a hiss when you take it off, that's normal, just fill it right up as much as possible, then put the cap back on tight.
let the leg down gently and try the trim, if it works get it up as high as possible and be very careful as there is air in the system and this could come down on its own trapping fingers !!!!!!!
once its up enough then prop it again and take cap of and fill again with oil then cap on again.
this needs to be repeated about 5 times tio be sure and make sure the engine goes full tilt up and down every time you check the oil.
yes the trim system can be hot wired.
phill
