1997 200 EFI Offshore stalls
Dixieland
ser #0G541432. Motor stalls as if ignition switch were turned off, warning beeps heard immediately after stall (as if ignition turned back on). Oil OK, temp OK, plenty of oil smoke. Always restarts easily. Seems effected(worse)in rough water. Is there a mercury tilt cut out? Diagrams show it but I can't locate it on motor? Could it be ignition switch? Motor has brand new ECM and fuel pumps.<br /><br />2nd. Problem. Motor floods with gas and is hard to start after trailering with motor tilted up. Found GAS (diluted) in oil tank on engine!! Any suggestions please??
JB
Re: 1997 200 EFI Offshore stalls
Moving to Merc Troubles
