norman phoenix
Thread starter- Joined
- Mar 18, 2012
- 3
Just bought this boat and before taking it out I noticed the plugs for the t stats epoxy'd in so I removed them. both plastic plugs were striped. ran engine with ear muffs and no water coming out of t stat holes. when I put my thumb over the water outlet port at the motor then water comes out the t stat port.. Installed water pump kit old one looked good but had to cut old impeller off shaft. ran again and still the same. Is it possible there is not enough water going thru the muffs. Engine was running at 1800 rpm.
