insomniac71
- May 24, 2005
- 7
motor is making a bit of noise so i started looking into things so i dont blow things up. i have a cylinder that when i remove the plug wire nothing changes......all other 5 noticeable difference when removed. recently did a carb rebuild floats, needle, seats ect. i just read you should not install the plastic washer on the seat on plastic version carbs....is this correct??? anyway i took the plastic carb portion back off to make sure the float was in properly....it was. i switched everything around....plugs, wires, power packs, plastic carb portion from one carb to that one to see if i could get a change in that cylinder but nothing. i think i pretty much ruled out any spark issue as far as no spark...weak spark...if i'm wrong feel free to fill me in. as for fuel i have a fuel water seperator and stock cone shaped screen on the fuel inlet at motor. i'm no carb genius but is there possibly a problem with the metal portion of the carb on that cylinder.....possibly a blockage in the rail at that cylinder?? tomorrow i'm going to shoot some seafoam directly into the throat of that carb to see if i get any change or should i use mixed gas??? thought i might have a dead cylinder but compression seems to be good.....all around 90. any ideas please let me know.
