Re: 1997 120Hp Force one cylinder not working?
However the water is getting into that cylinder, it doesn't look like it's due to any of the usual failures (head gasket, exhaust cover/baffle).
Years ago I had a similar problem with a motor only it was #1 cylinder. Had a marine machine shop check the block for cracks. Could not find any. Tried having the head gasket sealing surface on the block re-machined to true it up. Had the head itself machined to true it up. Nothing fixed it. Finally I replace the block. Got a used block and switched everything over and that fixed the problem.
Not saying that this is the problem in your situation, but whatever it is, it's something unusual.
