1997 115 evinrude wont start cold
crwise70d
i just bought the engine and it has been sitting for several years. it will not start when the engine is cold,unless I put gas in the carbs. any body got any suggestions?? thanks!!
Honorary Supreme Mariner
Do you understand starting procedure ?--------Do you have an owners manual ?----------Are you pushing the key in while cranking the motor over ??
crwise70d
No don't know anything about starting it cold and don't have a manual.
jakedaawg
Read how to start your motor in the sticky top secret files. Then ask questions shoild you need clarification.
Hint....the choke/primer only works while the key is depressed AND the engine is cranking or running. Pushing key in while not cranking does NOTHING.
James R
I would not even try to run this motor without a complete carb strip, clean a rebuild. Sounds like carb blockage. Could end up burning out one or more cylinders. Could destroy a completely good motor. Before you spend money check the compression's.
crwise70d
Yeah I'm going through it. It will start cold if you push in on the key. I appreciate the info. I am getting a manual. I have clean carbs,changed fuel lines and filter. Starts and runs good replaced water pump,changed oil in foot.everything is good.
